I'm using 4.24.
I'm getting a very poor resolution on my recorder & preview overlays. At first I was sure this was an interpolated/field overlay display issue or graphic driver problem. I've searched Edius for a place where I can choose either fields or interpolated frames in video overlay but can't find any. I've tried all the video overlay settings in Edius (and I did restart it), but the video overlay remains the same - Blurred and hazey. This happens in both SD & HD projects.
I'm using an NX card and Edius 4.24, the graphic cards I've tried are X800 256MB, and an Nvidia FX3500 with 256MB now using the latest drivers for both (as using older versions didn't help). Graphic cards run at 1024x768 32bits 75Hz.
The files show full resolution in other players like MMP or quicktime, only in Edius do they look like poo. Strangely enough Edius can show full resolution if it is not the application in focus. My overlay windows look right if I click on the taskbar or similar, if I return to Edius the interpolation haze returns.
Does anybody have better video overlay than the attached file, or know of a solution?
If so, info about software versions, graphic drivers would be great.
By the way - my video overlays look like the image to the right in the file!
BTW - Tweaking the driver antialiasing for video does have a small effect and the image is sharper, but still not as sharp as it should be.
