xdcam ex to sd dvd
  • xdcam ex to sd dvd
    I know this subject has been covered before but just wanted to know what others would do with a HD 1920x1080 50i 35 mbs xdcamex footage wedding from our ex3 and ex1 cameras.I usually shoot 720 50p for weddings but this particular church was the lowest light church I have ever worked in so chose to adopt 1080i,so should i go the way of Anton's Virtual dub conversion even with 1080i as his tutorial [which I have used before]seems to be mainly for HDV 1440x1080 or some other method to get the best dvd .
    I have procoder 3 and am using edius 4.61 atm.
    Thanks in advance
    Edius Version 7.4.Win 7 pro
    -Dual Xeon i7 2.66 Ghz x 5550quadcore NehalemHyper/Threading.SupermicroX8DAI motherboard. 1xwestern dig 32mb cache drive.2x 1tb samsung 32mb cache sata drives. 6x 2GB DDR3 ECC RAM.nVidia-gtx 760 card.Procoder3,Prodad,New Blue,Blufftitler After Effects,cinemasuite etc.
    The difference between 1920 and HDV 1440is not worth worrying about, in fact the results are no different, just follow the script replacing the 1440 with 1920 and you will be right
    Regards Barry
