Importing mp3 help please
  • Importing mp3 help please
    Hi,
    is there a way of importing mp3 audio into edius 5.1, I have loads of mp3 stuff I would like to use, but cant seem to get it in there. I'm trying to add file and then point to an mp3 track, and it wont do it, am i doing something wrong,
    any help most appreciated
    cheers
    stuart
    your MP3 files must be VBR as opposed to CBR. Since 5.01 VBR is not supported
    Either
    down convert Edius back to 5.0 or convert the mp3 files into something else that is supported ideally WAV 16 or 24 bit 48KHz uncompressed
      Edius can use VBR and CBR .mp3 and .wmv, but because the bitrate in CBR files is (well) constant they will work better. But not great.
      Not all .mp3's are created equally. It sounds like you may have some of those. If Edius will not open them, there's usually a good reason.
      Open your files in Audacity and save as .wav and all your dreams will come true!
        ..not true VBR MP3 was dropped from Edius since ver 5.01 onwards
          Best to convert them to WAV 48Khz.
            I agree use a batch convert and convert all mp3 to wav.
              So they won't even import?
              Good thing, they're trouble anyway.
              Maybe I should read the manual. :~)
                Cheers guys,
                downloaded Audacity and now ready to rock 'n roll
                Stuart
