Burn to disk problems!
  • Burn to disk problems!
    Have V5.1 But when i write dvd to disk get error code a00000003 Write to Blu ray is fine. Need a fix for this Thanks
    With the same HD project in timeline ?
    Did you change the project settings to SD before "burn to disc" ?
      Just changed project to SD But same problem! and error code!
        try burning a dvd with CONSTANT BITRATE SET AT 7mbs instead of the 8Mb it suggests
          In the burn to dics, there 2 options, did you select the right one....I cant access my PC right now, but I think it is the option on the left.......DVD, and another one...Ihad a similar problem when I first upgraded, only to find out that Ihad selected the wrong one....maybe you have the same thing.....
          ....just trying to help
            Done that still not working
              this is on the second "Tab"....... named >Style< ... on the left side = select DVD or BR
              .... on the "big" BlueRay....
              you are sure, this project is not to long for a DVD ??
              @ tuye
              Imho, in 5.11 you need not change to SD, you can burn from the HD-timeline direct
              (only titles on the title-tracks needs adapting, titles on V-tracks needs not adapting)
                The project is very short for testing so thats not the problem. I am set to DVD not blu ray. This worked fine in V4 Also i have re installed 5.1 just in case.
                  in Movie Tab, delete the sequence and add it again
                  set video bitrate CBR 7.7 and audio to ac3 256
                  in style tab, set DVD and 16:9 or 4:3 depending on your needs
                    No joy
                    Just did all that still not working! same error code
                      what is your project setting
                      what is the spec of the clips
                      can I see the actual error code?
