I just did a complete clean install of Edius 5.1. Captured a few HDV 720x1280 clips that were green screened with no problems. As soon as I apply the chromakey filter to the clips on the timeline, Edius crashes. Nothing else is installed on my computer but Edius. Duo core 3 Ghz Intel 945GNT MB. I have 4 Gigs of ram loaded. ATI X1300 video card. Anyone else having this problem?
Edius 5.1 crashes with chromakey filter applied
Tom Koveleskie - Director/Producer/Editor
Quarter Town Films - Independent Feature and Documentary Films.
Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.Tags: None
No problem with chromakey.
Runs without a problem.Steve
I am on XP SP3. The file is captured as a .m2t. Crash as soon as I apply the filter. I have to check and see if there is anything else that crashes it. With SD I never had a crash.Tom Koveleskie - Director/Producer/Editor
You may want to try removing 2GB of RAM to see if that makes a difference. Ordinarily 32-bit versions of Windows cannot address more than 2GB, and some systems are unstable with more than 2GB installed.
The other thing to look into are the video drivers. Make sure you use the most recent WHQL-signed ones available for your card.
THoff I tried all your suggestions with no luck. I'm scratching my head right now. I have a lot of green screen clips to process, go figure. For now I'll have to use AE or something else. None of the other keyers crash Edius. Could it be the video card? It is an X1300 ATI. Works great with SD. Thanks.Tom Koveleskie - Director/Producer/Editor
right click an m2t in bin and convert to HQ, then try chroma key on HQ clipAnton Strauss
Thank you Anton and THoff for the help. I got the problem sorted out now. The chromakey filter was crashing Edius with both m2t and HQ files on the timeline. Now I can use the HQ files without crashing. M2t still crashes Edius... But I know why now. It's a known driver issue.
1. I had ATI Radeon x1300 drivers installed. I needed to have VisionTeks x1300 versions installed.
2. Upon reading the "Known Issues" with the latest VisionTek x1300 drivers, I discovered that some types of mpeg2 files will play back corrupted. If VisionTek doesn't fix the problem, I'll have to buy another video card in order to work with m2t files.
3. As Anton suggested, I converted a m2t file over to HQ. Now chromakey filter plays nice, no Edius crashes.
Thanks again!
TomTom Koveleskie - Director/Producer/Editor
Argh... Edius is crashing again with the chromakey filter! It let me work with one m2t to HQ converted file. Tried a few other clips after conversion and crash. Now I'm really stumped... Anyone have any more ideas? I'm thinking Edius doesn't like my VisionTek ATI x1300 card for HDV editing. Don't know what else it could be. The latest drivers are installed.Tom Koveleskie - Director/Producer/Editor
Originally posted by Alter Ego View PostArgh... Edius is crashing again with the chromakey filter! It let me work with one m2t to HQ converted file. Tried a few other clips after conversion and crash. Now I'm really stumped... Anyone have any more ideas? I'm thinking Edius doesn't like my VisionTek ATI x1300 card for HDV editing. Don't know what else it could be. The latest drivers are installed.
There is a definate bug with 720P footage and chromakey which is being fixed. Only arrived with 5.1/5.11. Sure there will be a fix soon.EDIUS silver certified trainer.
Sounds like Zzzzz then. Maybe wait for 5.2 to be released ....TingSern
Originally posted by David Clarke View PostThere is a definate bug with 720P footage and chromakey which is being fixed. Only arrived with 5.1/5.11. Sure there will be a fix soon.Tom Koveleskie - Director/Producer/Editor
yes, confirmed bug, will be fixedAnton Strauss
I heard on the supplier grapevine. I was not sure how much was official but as Anton says it is official and will be fixed.EDIUS silver certified trainer.
