Best method for encoding Blu-ray and SD DVD ?
    Artefacts in text after sharpen
    I have followed Anton's steps through Virtual Dub, but find the following: When I import the Virtual Dub converted file into a new Edius project with SD PAL settings, and I apply the Sharpen filter, I get a lot of artefacts in text (see parts of screenshots). They remain visible after exporting to MPEG.
    When I import the Virtual Dub SD file into a project with HD project settings however, I do not get these artefacts at all. As I have not seen anyone mentioning this in the many posts about this subject, I am wondering if I am doing something wrong?
    Edius Workgroup 8.53
      You have probably missed this little tidbit:
      This HD to SD issue is not just in Edius. Many other editors are having difficulties in translation.
      Also, the sharper the image from your camera, the more you will notice the artifacting. An EX1 or EX3 will produce a very sharp image. This will translate to a lot of stairstepping in SD.
      To reduce 'digital harshness' I usually capture to MJPEG or Uncompressed analog. It is smoother, at least to my eye. My finals are pretty smooth as well. But on occasion I use Anton's method with virtual dub.
        The problem is the artefacts that appear in text, after sharpening which is the last step in Anton's method of downscaling HD to SD.
          what % of sharpness did you apply?
          I have not seen this problem, I am using TMPro for titles
          does the video look ok without sharpen filter? I often don't use one, it depends on the source
            I have used 8% (8 in sharpness filter).
            I have quickly compared 3 settings:
            VDub file imported in Edius Full HD project, with sharpness filter 8: soft
            VDub file imported in Edius SD DV 16:9 project, no sharpness filter: little soft
            VDub file imported in Edius SD DV 16:9 project, with sharpness filter 8: crisp, artifacts in text
            The difference in softness between filter/no filter in an SD project is very small compared with the difference in softness when exported from an HD project.
            So best compromise for now is not to use the sharpness filter, and export from an SD project. I wouldn't have thought the project settings would play such an important role.
            • #21
              Just my .02 cents.
              I have been trying the different methods and have settled upon encoding mpeg-2 straight from the HD timeline.
              But, I shoot in 720p60. So I do not have any interlacing issue to downconvert with.
              When I tried the virtual dub method the finished dvd turned out to be softer than the dvd straight from the HD timeline. Plus all of that extra work is a burden given how complicated everything is already.
              I seem to remember that anton shoots 1080i? Is this correct?
              Maybe interlaced footage benefits from virtual dub more than progressive footage.
              I am previewing on a plasma and an old DVD/CRT combo.
              Some jaggies, but to be honest, the same jaggies were there on the Virtual Dub disc.
              It sure is nice to be able to batch encode the DVD and the Blu-ray files in one swoop.
              • #22
                My footage is also interlaced.
                As to the artefacts, I suspect Quick Titler to be the cause. I created same texts plus styles with QT and TMP, applied a sharpness filter and there you are: artefacts in the QT text, but not in the TMP text.
                So nothing caused by the method with VDub, but a bit disappointing for QT.
                • #23
                  this is why I never seen such a problem because I don't use QT
                  • #24
                    if you add the VD SD file to a HD project, then it will look super soft, because it is being upscaled to HD
                    so always place VD SD file in SD D1 project Pal (not DV project)
                    and in NTSC countries, place the file in SD DVD project setting and not DV
                    • #25
                      It is very easy to switch between project settings in Edius....so you could just duplicate your final sequence and lable it SD version then remove the clips from this new timeline leaving the titles and any markers used for chapter points etc.
                      Then you can export the HQ final from the original sequence minus the titles and do the VD downconvert....re import and drop on to the SD version sequence timeline copy....change the project settings to SD DVD and make needed adjustments to clip & titles.
                      Now when you print to DVD your CG has only one render to undergo so it should not suffer from un needed compression artifacts...the sharpness filter can be added to just the video track if needed so as not to affect the titles.
                      Maybe usefull for those without TMPro.
                      Regards
                      Dave.
                      www.nakedeyedv.com
                      • #26
                        This issue is so dependant on subject matter, length, prefered workflow etc. My normal approach had been to export HQ fine file to use both in Vegas/Architect for Bluray and in TMPGenc for downconversion and encoding for SD DVD then use DVDLab pro. This is still my preferred approach if there are no problems. To me for my 2 hour plus programs of theatre and dance it is the quickest and produces the best looking output in the shortest time. I have had two instances where I had sets on stage that resulted in shimmering lines on diagonal tiles. The Vdub approach resulted in a better output but the issue was still there just less so and whatever I did the output lacked the sparkle of the TMPGenc approach. I did an in camera down convert from the FX1 with the original tape and the problem was there as well!!! I use TMPGenc because to me it has the best encoder for these low bit rate conversions of any of the encoders that I have. I just did a 2 hour 26 min dance show, for cost and convenience ( customer choice) this was on a single DVD ( about 3650 ave, 2000 min and 8000 max AC3 196) I did this both ways, VDub and TMpgenc watched both on CRT and Plasma( regular input and PS3 upscaled) and still choose the TMPGenc version. For Bluray I used the HQ file in Vegas to set markers and encode for DVD Architect (MPEG2, 18000 min, 21500 ave, 30 max AC3 256). Source for this video was FX1 HDV native, and SR11 and XR500 1920x1080i AVCHD converted to HQ.
                        Ron Evans
                        Ron Evans
                        • #27
                          Ron, I have been trying for weeks without success to get DVD Architect to accept files without re-rendering.
                          Using 1440 x 1080 setting for Blu-ray MPEG 18000 - 23500, and AC 3 audio @ 256. (which always gets re-encoded too)
                          I don't have Vegas, but have you or anyone else managed to get compliant files into Architect straight from Edius without re-encoding for Blu-ray?
                          It's very frustrating,
                          Cheers,
                          Vaughan
                          • #28
                            It has been ask and explained before (long ago) that D1 and DV doesn't make any (much) difference when starting a SD project using DV avi footage, please clarify why it does make a big difference now. TIA
                            • #29
                              No Vaughan, I nearly always encode outside of Edius for all sorts of reasons.
                              How did you get DVD Architect without Vegas? I thought the only way to get DVD Architect was with Vegas that is certainly how I got DVD Architect as it came with an upgrade to Vegas. Vegas is more convenient for setting named markers that transfer to DVD Architect as named chapters, having a preset for DVD Architect and is quite happy to use either a HDV or HQ file ( at least 32 bit version as there is no 64bit HQ codec).
                              Ron Evans
                              Ron Evans
                              • #30
                                D1 is upper field first and matches the whole process of making DVD, which is also upper field first
                                this is why edius also calls it D1/DVD in Pal and DVD in NTSC
