I've been trying to burn a dvd directly from Edius ( I use the Procoder to put it into DVD files, then follow through with a burn) but it will not recognize dual layer media in the drive. It says there is "no media" in the drive. I swapped out my drive with a better drive, with no changes. I'm able to burn with Nero, so the drive and media must be ok. I'm using Edius 4.61.
Edius DVD burner doesn't recognize media
What type of media are you using? allways use good quality media like Taiyo Udin, TDK,
SteveMain system, Supermicro X8DAH+,Dual Xeon X5680 cpu's 24 cores,2x1400watt power supplys,SC747TG-R1400B-SQ Case,192GB 1333mhz ECC Registered ram,8 x 480GB Intel 520 SSD drives,Windows 7 64 bit ultimate, GTX 670 4GB ,2 x Sony BWU300S Blu-Ray burners, 1x Sony DVD burner,LSI 9266 Raid Controller with Cache vault & fast path Lic, ESI MayaE Audio,HD Spark,Blackmagic intensity Pro,TMPGenc 5,Episode Pro 6,Sorenson 9 Pro,Alcohol 120 V2, Edius 6.53,Dell 27"LCD,HD Spark, Powershield 3000VA UPS. -
I've been trying to burn a dvd directly from Edius ( I use the Procoder to put it into DVD files, then follow through with a burn) but it will not recognize dual layer media in the drive. It says there is "no media" in the drive. I swapped out my drive with a better drive, with no changes. I'm able to burn with Nero, so the drive and media must be ok. I'm using Edius 4.61.Anton Strauss
Your problem is not an Edius issue.
If Windows will not recognize your discs, neither will Edius.
I tend to use cheap-o discs as scratch copies until I get it right, then I switch.
Printable HP's have not failed yet.Rusty Rogers | Films
Twain - "Glances at History" 1906Comment
What about deleting the upper and lower case filters in the registry, then restart the computer, if you do a google search on how to delete the upper and lower case filters you will find it, this should fix the problem for you.
SteveMain system, Supermicro X8DAH+,Dual Xeon X5680 cpu's 24 cores,2x1400watt power supplys,SC747TG-R1400B-SQ Case,192GB 1333mhz ECC Registered ram,8 x 480GB Intel 520 SSD drives,Windows 7 64 bit ultimate, GTX 670 4GB ,2 x Sony BWU300S Blu-Ray burners, 1x Sony DVD burner,LSI 9266 Raid Controller with Cache vault & fast path Lic, ESI MayaE Audio,HD Spark,Blackmagic intensity Pro,TMPGenc 5,Episode Pro 6,Sorenson 9 Pro,Alcohol 120 V2, Edius 6.53,Dell 27"LCD,HD Spark, Powershield 3000VA UPS.Comment
