Edius 4 installation problem.
  • Edius 4 installation problem.
    Hi,
    I have just formatted my HD and now I have installed drivers and software.
    I have Edius NX card PCIExpress.
    I have installede Edius 4 but wnen I open it and I like to configure it I see some wrong thing.
    For example in Device of Output I don't see any entry that refear to Edius NX, I see only some "Generic OHCI HD" entry. I don't see any Edius NX entry.
    I have not installed any codecs, I have only installed the drivers but I think I have made some errors.
    Can you help me please?
    CPU: Intel i9 7940X
    SSD Drive:
    (C) 512GB Samsung 960 EVO PCIe M.2 NVMe (Windows 10)
    (D) 2TB Samsung SSD 850 EVO 2TB SATA III 6Gbit/s (for video exporting)
    (E) 1TB Samsung 960 EVO PCIe M.2 NVMe (for video editing)​​
    Most likely, the NX drivers didn't install correctly (if at all) when you did your reinstall.
    Put your EDIUS installation disc (or download the most recent update) and locate the 'drivers' folder - within there you should find a folder for 'NHX-E2' or something similar.
    Run the associated setup program from that folder.
      With your help I have solved my problem. Thanks a lot.
      I have to ask you a different question.
      Can you tell me what Buffer have I to confugure in Edius 4?
      Thanks again.
      CPU: Intel i9 7940X
      SSD Drive:
        Typically the buffer setting is found under the Hardware Settings menu in EDIUS. If you have 1-2GB, go ahead and set it to the highest value (96).
          Thanks now I have a last problem but I think it is impossible to solve it.
          My Edius 4 doesn't work in realtime. When I add a 3D transition Ediius 4 stops on the transition. I have to make rendering and everithing is ok. If I add the XEnVidiaATI files, Edius 4 desn't make anymore any transition. If I make rendering I see a green screening only without transition. I use SAPPHIRE RADEON X1950XT 256MB GDDR3 and I don't know why I have this problem.
          thanks
          CPU: Intel i9 7940X
          SSD Drive:
            If you are using Xplode for your 3D transitions, these aren't really designed for realtime playback (particularly in the world of HD).
            We did, at one time provide that ATI/NVIDIA renderer, however is it very outdated and unsupported. If you search around, you might be able to find some 'home brew' recipes to get basic realtime functionality, but again, it's not assured.
            The non-Xplode 3D transitions should play out in realtime, unless the PC itself is slow (CPU) or the transition is particularly long.
              Yes I am using Xplode Pro and I have a lot of problems with 3D transitions.
              I don't understand when you tell me 'home brew'. Where can I find it?
              I hope you will help me.
              thanks
              CPU: Intel i9 7940X
              SSD Drive:
                'home brew' recipes
                home-made
                self-made
                hand-made
                self-tinkered
                handicrafts
                not official support....... even "cake by home brew recipes "
                not garantie that it works in your case.....
                only your risk.....
                needs flashplayer....
                you wish a link >> call vienna ... old Hans
                Moroni >> Utha ???
                Moroni >> Komoren ???
