In Edius 3.x was an option "delete spaces shift" ... in Edius 4 is only "Delete GAP" or not?
Multi GAP (spaces) in Edius 4
This is even faster in 4.x.
Select the "gapped" clips and hit Backspace.
Sync Mode operates slightly differently, but you'll get it.
RustyRusty Rogers | Films
to delete all gaps on a track, select the track with CTRL+A and press backspace
to delete all gaps on timeline, select all with Shift+A and press backspace
to delete gaps between a couple of clips, rubber band or CTRL+Click the clips in question and press backspace
to delete a single gap, select the clip to the right of the gap and press backspaceAnton Strauss
