if the clip speed is changed for the first time in the duration(timecode) field everything works like it should, if the changed clip is reopened and the i try to adjust the duration levels by frames, seconds doesent matter the "Rate" level inverses! if it has a Rate of 70% and the duration levels are touched the Rate changes to 130% or viceversa.
so back to version 5.01 since i need this all the time......
thomas
thomas
