bad quality converting from timeline
  • bad quality converting from timeline
    Hi..I think I get crap quality videos after converting from timeline...vmw, m2p..Only thing I get reasonable quality is with quicktime/flv....so where am I going wrong
    A computer with a lot of stuff in it :)
    What are you converting? What are your project settings?
      Hi..I am converting SD pal 25p over 50i 16x9
      I have theese settings
      Frame size : 720 x 576
      Frame rate : 25,00( 25/1 )
      Pixel aspect : 1,4222
      Field order : Progressive
      Audio
      Rate : 48000Hz
      Sample size : 16 Bit
      Channel : 2
      Setup
      Rendering format : Canopus HQ AVI
      Over Scan Size : 3 %
      Audio Reference Level : -20,0dB
        Field order : Bottom field first .
