Shortcut list for Edius Pro 3.x
  • Shortcut list for Edius Pro 3.x
    I have bought a dedicated Edius Pro Keyboard and asked the shop whether it is suitable for v.4.x as well and the response was yes. Now that I connected it, it seems that some keys don't do what's printed on them, and was wondering if things have changed materially for version 4?
    Does anyone know where to find the old v3.x shortcuts so I can compare?
    Many thanks.
    Sascha
    try this:
    I remmber me to the solution from your question in a other thread.....
    I search for it.... I found it.....and reality => it was my last search on this forum .....
    The colors \brightness\fontsize from this forun (specifically the searchresult) simply impertinence
    @ everyone >> please, try a Advanced-Search, with " Show Results as Post" i.e. : for all post from "GrassValley_BH"
    and scroll the site with the results from top to bottom, and trying to read the text...
    and replay with true words your perceptions.........
    Originally Posted by Butcher
    I need to print out the keyboard shortcuts and memorize them all. I'd customize them if I could, but too many people share the system and I don't think they'd appreciate it. :-)
    EDIUS Keyboard Shortcut Translator (takes your .DAT file and makes it human-readable)
    __________________
    -- Brandon
    I am not in Technical Support. I'm not Branden.
    If you have an urgent need for support, please contact GV support directly!
    Private Messages for support will be ignored and deleted.
    you wish a link >>> call not vienna,
    vienna eyes are heavily damaged behind 7 min search in this forum.....
    or wait for european night, than I will you send my "Edius 3.5.xls" if you give me a emailadress as PM....
    a) sorted per key
    b) sorted per funktion
    friendly greetings from ViennaLowLevelService ........... old Hans
      They have changed from 3 to 4. On the Setup-CD Edius 4 is
      an importable Shortcut-File for Edius 3.
      Wolfgang
      Edius 4.54/3.62
      NXe / RaptorRT2 max
        I have looked at edius keyboards from time to time, and I have found a bunch that say they are for v 3 and just a few that say v4. I've guessed you could get to the same place by reprogramming edius to match the keyboard, so I guess that is where you are.
        Harris
        edius pro 8.2, win10 pro x64, i7 5930K @ 4.4 on asus X99-A usb3.1, corsair h100i gtx with noctua fans, 32G gskill ddr4, gtx 980 4G, system 256G samsung ssd 950 pro M.2, swap 128G samsung ssd 850 pro, general use 512G samsung ssd 850 pro, video 4 @ 3T WD red pro in raid 5
          here is the .xls from3.5
          one table sorted per key, the other table sorted per funktion
          you wish a .xls >> call vienna.......... ;-)
          [edit]
          nope, it is not here
          maybey, it looks the "upload-funktion" are censored by the moderators ???
          maybey, it looks the attachment needs a "enabling" behind consistency check ...each time ....each file ???
          if it is so.... please tell this in future on the "upload-windows".....
          I try 3 times the upload from the 52KB ...xls, ....before I give up.....
          [/edit]
            here is it real ..... needs no "log in" (so I hope)
            Achtung, nur ein Versuch ein benötigtes .xls hochzuladen, welches mir im Ami-forum (scheints aus Zensur-Freigabe Modalitäten) nicht gelingt... […] friendly greetings from ViennaLowLevelService ........... old Hans
            but in the german GV forum is ".xls" a forbidden format to upload....
            maybe, .xls is the devil himself or at least his grandma ?????
            therefore I have it hidden behind "rename to .txt".......
            therefore, please rename the file "shortcuts 3.5 for web .txt " to "shortcuts 3.5 for web .xls"
            on Canopus or GV-forums, you have to learn >card-playing with the devil< ...*g*
            PS: please can anyone try the download + rename procedure...., and replay the result ??? ...thanks....
              Vielen Dank, Hans, much appreciated!
                Hi Wolfgang, I checked my installation CD and can't find any .dat files on it. Where exactly should I look for this importable file?
                Is there actually an Edius 4 keyboard out there (in English)? All I found so far is a German version, and everything else seems to be for versions 2 or 3.
                  I believe the shortcut files are on the Bonus disc.
                  WorldTech Devices has an English EDIUS 4 keyboard.
                    The forum filters by file type...
                      Greetings Dear Brandon......is above "quote" adressed to me ???
                        Hi Hans, yes, and xls is supported now it seems.
                          Hi Brandon..... I know now the problem, it is is imho a "forum setting-bug"
                          I will not hijack this topic topic to explain this
                          I try a new topic, and delete later the (my)"OT" post
                          old Hans
                            Thanks Brandon, I found it on the Bonus CD, next to a shortcut import for Avid and FinalCutPro as well. Thumbs up for that!
