Capturing DV With MS Codec
  • Capturing DV With MS Codec
    Somebody came to me with several DV tapes that they want captured to a hard drive (they want to then edit/use the video for their own purposes). I was about to capture and realized that I should use MS codec instead of the Canopus codec if they were to do the editing. Is there a way to force Edius to capture using MS codec? Pretty sure I've done this when I had Scenalyzer on my system but not quite sure how to do with Edius.
    Using Edius 5.
    bejay
    Primary - Gigabyte 890FXA-UD7 / AMD Phenom II X6 1100T / 8 GB RAM / ASUS Radeon HD 6850 / HDSpark / W7Pro64 / Edius 551 / ProCoder 2
    Secondary - Asus P5Q DX / Intel Q6600 / 8 GB RAM / NVidia 8600GT / W7Pro64 / Edius 551 / ProCoder 2
    not sure if it helps but you could try DVCapture
    Paranova Films
    Cali - Colombia
    http://www.paranovafilms.com/
      Actually I'm pretty sure DV Capture isn't on my system. I could reinstall Scenalyzer but I really don't use it anymore and don't like installing software for "one time" projects.
      I have CS4 installed, but never use PPro - maybe I can fire it up and learn how to capture with it.
      bejay
        dvcapture is on the edius 5 disk and the latest version is in the download section.
        It has the ability to capture in MS format
          OK thanks - I'll certainly have a look at it. I wasn't aware it even existed.
          bejay
            Just looked at the product info for DVCapture and wonder if this statement may prevent my using it:
            You must have one of the following Canopus products installed to use this software:
            * DVStorm Series
            * DVStorm2 Series
            * DVRaptor RT Series
            * DVRex RT Series
            * DVRex M1 w/ RT Option
            * DVStorm XA/EDIUS DVX
            * EDIUS Pro v4.1
            * EDIUS Broadcast v4.1
            * EDIUS NX Series
            * EDIUS SP Series
            My Storm system is being used for another project - I was hoping to use the Edius/Spark system for capturing.
            bejay
              It works for me with Edius 5 if I have the dongle attached.
                Thank you - I will give it a try.
                bejay
