Titlemotion Problem after 4.24 Uppdate
  • Titlemotion Problem after 4.24 Uppdate
    I updated to 4.24 and now when I open a saved Title in Titlemotion Pro and change it, then try to save it I get:
    "A sharing violation occurred while accessing E:\WLCC\EdiusTites\Psalm119.ICG." I am forced to save it as a different name. I cannot change any previous title without the error. Any Ideas?
    Have you tried to reinstall Titlemotion? I would recommend that.
      Sharing Violation
      We are getting this error with TMP pro 36 on a regular basis on two different systems using edius 4.24. It is very annoying after you have made several changes and nothing gets saved.
      tdtinker
      tdtinker
      Edius 8.5
      www.actvp.com
        no such problem with Edius 4.03
          Tmp
          So is there a problem with Edius 4.24?
          tdtinker
          Edius 8.5
          www.actvp.com
            don't know, have not tried 4.24
              Tmp
              It looks like the powers that be are staying away from this question. I just hope it is fixed in 4.51
              tdtinker
              tdtinker
              Edius 8.5
              www.actvp.com
                Hi,
                I am using Edius 4.24 and apart from a problem installing TMPro which was overcome I have no problems using TMPro either creating new, opening old and modifying it and saving.
                I assume you have installed TMPro AND its update
                Keith
                Dual 3.06 Xeon, 2Gb memory, NX card, Edius 4.6, Procoder 2.
                  I have no problems with 4.24 and TM Pro
                  Mule
                  EDIUS v5.51 Broadcast - Dual Xeon Supermicro X7DWA-N with E5450 3.0GHz CPU (8 cores)
                  4 GB Ram, 1.0 TB Video Raid (2x500). 5 ea 1.0 TB External Video. 2 500 gb Ext, 320 GB OS Drive .. ATI Radeon HD 4350 with 512 Ram XP Pro with SP 3 HD Sparks, VisTitle
                  Edius 6.52Dual Xeon Asus P5E3 9650 3.0 4G Ram
                  Nvidia9800, 500G Raid (2x250) 1TB&500TB Ext Drives
                  HPX 2000 AVC Intra, HVX 200, HPX 170, AG-AF 100, Canon D5 MKll.....MacBook G4 w/VMWare FCP Edius 6.2
                    Yes both systems have been updated. If it was just one I would think it was the system, but on two different machines I have to wounder.
                    tdtinker
                    Edius 8.5
                    www.actvp.com
