Hi,
Using HDStorm with EDIUS 5.01, but having a few issues.
1st. When I go to capture HDMI video with eight-channel LPCM using the capture -> capture tab, it seems to only be recording one mono channel. But if I use the capture -> audio capture tab, it seems to record all eight channels. Am I missing something?
3rd. How do you enable HDMI pass-through during capture? I have only been able to get it to work when playing a clip on timeline or when outside of EDIUS using HQX-E1 Monitor.
2nd. I've been having some issues with 720x480p videos exporting/playing as 640x480p after doing print to file. I also have some issues with 1280x720p videos exporting/playing as 960x720p after doing print to file. Any help here?
Edit: Think I found the problem for the 3rd issue and 1280x720p display.
It seems it is adding an (AR of 3:4) when it should be (AR 1:1).
I'll have to see how if I can find out how to change it on export.
