is there a way to ramp video speed in edius pro3
  • is there a way to ramp video speed in edius pro3
    is there any way to ramp up a speed of a video clip using keyframes in edius pro 3. Like starting at normal speed and ramping up to say 600% over several seconds
    No.
    But if it's DV footage, try the DV Speed Controller off the desktop.grassvalley.com site.
    The only other way is to just cut at a point and speed it up, then cut again and slow it down. But that's a "sudden" ramp change and not smooth.
      just chop that clip into a bunch of section and apply speed change manually to each section and it will looks pretty good, this is a one hand tie behind your back workaround, I do it all the time. (-:
