I have been editing two different weddings using my SD cards transfered to the hard drive from my Sony V5U. The first plays great no problems even with 5 streams of video at once. The second stutters and stops and won't let me edit without lots of waiting. Is there a way I can change the second file's frame rate and frame size to match the first one? Not even sure why the two projects have different frame sizes and frame rates because I thought I did the same thing each time.
See below for the info on each of the two projects.
HELP!
Project file 1
Project name : Our Wedding
Folder : G:\Ralph and Michelle\
Modified : 3/6/2009 6:59:06 PM
Video
Frame size : 1440 x 1080
Frame rate : 29.97( 30000/1001 )
Pixel aspect : 1.3333
Field order : Top Field First
Audio
Rate : 48000Hz
Sample size : 24 Bit
Channel : 8
Setup
Rendering format : Canopus HQ Standard
TC preset : 00:00:00;00
TC mode : Drop frame
Total length : --:--:--;--
Over Scan Size : 3 %
Audio Reference Level : -20.0 dB
Panning mode : Standard
Color space conversion : Standard
Project File 2
Project name : Lauren and Chris Brenham
Folder : G:\Lauren and Chris Brenham 3 7 09\
Modified : 3/12/2009 9:48:32 PM
Video
Frame size : 1280 x 720
Frame rate : 59.94( 60000/1001 )
Pixel aspect : 1.0000
Field order : Progressive
Audio
Rate : 48000Hz
Sample size : 16 Bit
Channel : 2
Setup
HELP!
Project file 1
Video
Audio
Rate : 48000Hz
Channel : 8
Setup
Project File 2
Video
Audio
Rate : 48000Hz
Channel : 2
Setup
