Render speed question.
  • Render speed question.
    Hi
    I have some 1920 x 1080 HQ footage I want to convert to DV. If I take the footage to ProCoder 3, the calculated time is aprox. 2 hrs for preset DV AVI WS. If I put the same files onto the timeline inside Edius it will only take aprox. ½ hrs.
    Does anybodu know if I do something wrong in PC or has to change something there.
    /Ulf
    Best regards * Ulf * Denmark
    mail to me
    Ulf
    I take it you are using Edius 5 from the time you quote.
    E5 is miles faster than Procoder 3 and I cannot find any difference in the quality, Make sure you select the Highest quality in the advanced tab.
    Procoder only uses 25% of my quad core and E5 sets them singing or melting at 100%
    Regards Barry
    GB GA-X58A-UD3R MB, i7 990[email protected], 12G 1600mhz Mem, Samsung EVO-250G SSD, 3x2T RAID, GTX 970W OC, 2x24 inch LG Monitors
      Thanks Bluetounge - just thought it was strange, but it's no big deal - I just drop to timeline and export.
      /Ulf
      mail to me
