Corner Pinning
  • Corner Pinning
    I just don't understand with all the wonderful upgrades they did to
    Edius still we have no corner pinning capabilities.
    lauri
    Using Edius 6
    I have certainly asked for it in the past.
      what exactly is corner pinning? sounds like something nailed to the corner so it can't move?
        yeah on the side of your house Anton, go and have a look....he he!
          Hi Anton
          This link has a good demo of the function
          Intel Quad Core Extreme 3GHz/12M, 4Gb RAM, 2Tb Hot-swap (ARAID), NVIDIA GeoForce 8800 GTS, Edius Broadcast 4.61 / Edius 5.5, Procoder 3, DVDit Pro HD, Sonicfire Pro 5, Mercalli, Vitascene, Adorage. TwinPact 100, Pegasus, TMPro. VirtualDub
            well that was a tutorial on motion tracking/image stabilization
            similar to what Mercalli does in edius
              Hmmm Not quite the same as Mercalli. Mercalli stabilises the entire image. Corner pinning seems to create a set of keyframes that another image can use to track the movement of the first image. There's no real stabilisation involved, in fact, quite the opposite. Corner Pinning makes a second stable image move just as much as the first so that the two movements are synchronised.
                oh, I get you now
                  At the beginning of the video do you see how he is pulling the
                  corners out one at a time? That is what I'm talking about.
                  It enables you to pull in or out one end point of a clip without having to manipulate the entire clip. Very useful for example if you were
                  trying to place an image in lets say a television that was not shot straight on and all you need to do is manipulate just one side
                  of the clip to make it fit seemlessly.
                  Lauri
                  Using Edius 6
                    I would do that in After Effects - then import the video into EDIUS. There is no video effect in EDIUS today to do that.
                      New Blue has it in Video essentials III, I think they call it Image mapping. I'm not crazy about the controls but it works. I'd rather see it as part of the Layout tool.
                      I7 2660k, 32GB ram, nVidia 570, Win 10 Home
