Project Settings - What's the difference between . . .
  • Project Settings - What's the difference between . . .
    720x480 59.94i 4:3 (DVD)
    and
    720x480 59.94i 4:3 (DV)
    with the HD Storm or:
    720x480 59.94i 4:3 48Khz 2ch
    in OHCI mode
    The latter two use lower field first. The DVD preset uses upper field first.
      So, if I'm editing in DV, but the final project is for DVD, which preset should I use for the project settings?
      Inquiring minds wish to learn . . . . . .
        Probably DVD.
          Well, probably I will need to experiment, as I just produced 2 DVDs using the DV preset, rendering to mpeg and authored using MF5, and they looked marvelous . . . . . .
          Oh, it's always sumpthin'
          Thanks Mr Sparkle
            it does not matter if you use DV or DVD
            either one will give you the same resulting DVD as long as you set destination field order to upper when exporting to mpeg with whatever you use for mpeg encoding
            the source can be lower field (DV) or upper field (DVD), never change the field order of the source
              If you're editing DV then use the 'lower field first' preset.
              If you're editing from a ripped DVD for example,
              which is top field, then use the 'upper field first' preset.
              This way it keeps the original footage in it's original field order.
              Once you export to DVD or DV tape etc... that's when the field order can be changed for each export requirement.
              GESTOS PRODUCTIONS
              www.gpvideo.com.au
                Yes it all makes sense now. Should have thought it out before posting!
                Thanks all.
                  keep in mid that using the DVD preset also produces 24bit audio instead of the default 16bit required by the DVD spec audio and not all encoding software supports this
                  DVD spec is 16bit
                  Edius DVD preset is 24bit
                  however, it will be changed back to 16bit when doing the mpeg encoding, as long as your encoding software supports 24bit source files
                    What if you're importing and editing both DVD and DV
                    formats in the same project ?
                    Windows 10 Pro 64bit, Edius 7.53, Antec DF-85
                    Corsair 850Watt P/S,ASUS P6X58DE,
                    Intel Core i7 960 3.20 Ghz Bloomfield,Corsair 12 GB RAM TR3X6G1600C8D-R,PNY GeForce GTX570
                    WD 600GB 10k RPM System Drive,
                    WD Caviar Green Video Drives 1GBx2,G-Raid 2GB Backup Drive,Pioneer BDR-206 Blu Ray Drive
                      Don't worry Providing the DVD mpeg clip on the timeline is "Upper" and the DV clip is lower and your Project setting is "Lower" for DV, Edius will take care of it and play back and export correctly.
                      Regards Barry
                        Ahh I see. Thanks Bluetongue.
