HD Spark + HD Storm Bay
  • HD Spark + HD Storm Bay
    I am building a system for a customer who wants HDMI output and AV/DV input. Since I prefer to use Windows Vista 64 bits and appearently the HDStorm does'nt work with that, I am looking for an alternative solution.
    Will it work to use a HD Spark for HDMI output and a HD Storm Bay connected to the onboard (Asus P5QL-E) firewire for DV and analog input?
    Thanks for any suggestions.
    HDSTORM Bay requires an HDSTORM board. There's no alternate means of interface for the bay..
      Thank you for your quick reply!
      Best regards, Arthur
        No problem - for analog ingest, you should look at our ADVC range to fill the gap.
          I was thinking about that, but internally would have been nicer.
            Then consider the ACEDVio, which is an internal 32-bit PCI card with the same connectivity as the ADVC-110.
