XP64bit, edius 5 and plugin for cs3
  • XP64bit, edius 5 and plugin for cs3
    guys i have a problem in edius 5..
    my system is canopus SP-SDI. i install edius 5 on windows XP 64 bit..
    everything is fine. just while capturing its giving me out of sync.
    i change the setting in hardware setting to free run.. its capturing fine again then again next day its goin out of sync and i should change the setting to free run again..
    its changing by it self.. is it bug ? do u guys have any solutions for this ?
    another thing is aftereffect cs3. i paste the edius video out plugin in it but no out put !
    is the plugin not supproting 64 bit ? any solution ?
    upgrade to edius 5.01
    under ae prefs look canopus video out and enable (i suggest not to use with edius opened)
    Paranova Films
    Cali - Colombia
    http://www.paranovafilms.com/
