Bin - changing properties of mutliple clips?
  • Bin - changing properties of mutliple clips?
    Is there anyway to change the properties of multiple clips in the bin all at once?
    Normal Windows method (shift or control key/select) does not work.
    It's a bit of a pain to say the least to have to individually change aspect ratio and field order for each and every clip one by one when there are dozens to do.
    I searched the Product Feature Requests section and didn't find anything posted, thought I would check before adding such a request.
    Claire
    Man I WISH this was possible......but it ain't :(
      if you change the bin view to list view instead of thumbs, you maybe able to dhange some properties of all selected clips, by the dropdown submenu that appears on any of the selected clips, I am not sure in which version this was implemented so be sure you got the latest
        Implemented? I'm trying with 5.01 and no success here.... No matter what bin view I chose, or how many clips I select, it only affects the clip I right click on.
          I did not mean right click, but before I open my mouth too much, can I see a screenshot of your bin in list view
            Thanks Anton :) I hope you're right!
              sorry, the right hand side of your screenshot is not expanded, I need to see all columns, especially the aspect ratio column, these should have dropdowns
                OHHHH!!! That might be it! I'll give it a shot :)
                  Click to Enlarge
                  Still no luck.....is this more helpful?
                    hmmmm, let me scratch my head for a while
                      ....Are you going to look like "Kojak" ? :lol: :)
                      Engineer for Digital Point production ltd.
                      Video & Video
                      The Official Italian Forum for Techinical Support to EDIUS.
                      http://videodintorni.forumfree.it
                        no, but I may get hit over the head
