Since you have version 4, you need to use the ProCoder Express Wizard.
Choose by filetype in the wizard, and pick AVI. You will eventually get to a screen that has an 'Advanced' button. Click that, and then change the encoder to DivX (from RGB uncompressed, or whatever the default is).
You'll need to use the DivX codec's calculator to work out the bitrate needed to make it exactly a certain size.
__________________
Kenneally Harder
Thomson Marketing, Communications and Branding (San Jose)
Steve EDIUS Trainer, Grass Cutter Gold
