video card going out?
  • video card going out?
    what are the signs of this? i will be editing and then the screen go blank
    not good.where can i go on my settings to see what video card i have
    Right click on My computer, select manage and on the next window on the left side select Device manager, you should see what card you have under Display Adapters when the list is populated.
      Right-click on the desktop, and select Properties, (or Nivida if that option is available). Everything about your Video Adapter will be available from there.
      Also Right-click the "My Computer" (or "Computer" for Vista) icon, select Manage, select Device Manager, details on the Display Adapter Settings, drivers etc are available here. (Tip: Make sure you have the latest drivers installed from the Manufacturers web site)
      Intel Quad Core Extreme 3GHz/12M, 4Gb RAM, 2Tb Hot-swap (ARAID), NVIDIA GeoForce 8800 GTS, Edius Broadcast 4.61 / Edius 5.5, Procoder 3, DVDit Pro HD, Sonicfire Pro 5, Mercalli, Vitascene, Adorage. TwinPact 100, Pegasus, TMPro. VirtualDub
        Or remove the card and clean the terminals, this is a common problem.
