I have been recording VHS tapes onto my hard drive for the past couple of days using an ADVC 110 and Edius Neo with the default codec. I did not have any problems with the first few, but this last one I tried started cutting out near the end of the tape. The picture would run for about half a second or so and then cut out for half a second or so. I get the impression that the card or the program thinks that no video is being input for that time. I would like it to just record straight through anyway. Is there a way to do this?
Thanks,
Justin
Thanks,
Justin
