Hi, I recently bought the ADVC-HDM1 converter and two things have puzzled me. I'm using a Sony HVR-M15U HDV VTR, and a Matrox Axio running Adobe Premiere Pro 2.0 for these tests.
The first regards the remote control for this unit. I'm playing some content recorded in [email protected] HDV format, which passes through the ADVC-HDM1 converter and outputs HD-SDI.
I connected the HD-SDI to my NLE station, and tried to remote control the unit, using an Addenda RS-2/3. The Addenda has been used without any troubles to remote control Sony VTRs. Now, I connect the Addenda RS-422 connector to the ADVC-HDM1 converter and try to remote the Sony HDV VTR without success. The Remote Control software used inside Adobe Premiere is Pipeline Digital ProVTR, but as I said, it worked with Sony VTR's without any problems.
Why can't I control my Sony VTR through the ADVC-HDM1, using Adobe Premiere? I tried both device and controller connectors for RS-422 in ADVC-HDM1.
My NLE doesn't have TC in connector, but Timecode always comes with the RS-422 remote connection, so I can still do frame accurate editing. With ADVC-HDM1, I don't get remote control, neither TC information.
How can I solve this?
