Mac OS X 10.5.4 and picture controller will not mount
  • Mac OS X 10.5.4 and picture controller will not mount
    I just purchased my first Mac computer and was installing picture controller for my ADVC-300. It downloads fine and when I try to install, it tells me "PCtrl300.dmg no mountable file systems" I have searched and search the internet for a solution and no luck.
    I did already make sure the file was to be opened by DiskImageMounter and Repaired Disk Permissions.
    Any suggestions?
    Not sure what could be going on - I just downloaded the file in question to my crusty old G3 Powermac here running Panther, and it mounted without any issue.
    What filesize does CMD+I report for the DMG file?
      It's 340 KB
        Hmm, that's correct. I'm wondering if the DMG has some incompatibility with Leopard.
        Did you try the CD that comes with the unit? I believe it is a hybrid disc..
          no, unfortunately I have misplaced my install cd's during our last move.
            Try this then. It might work..
              That Worked Flawlessly!! Thanks so much for your time and effort!!
                I can't find my media but the above attachment link doesn't work :(
                  You can download Picture Controller and the User Guide for the ADVC-300 from here:
                  but you must first create an account and register your device if you haven't already done so.
                  Ken.
