I am having a problem with our new ADVC700 and Windows Media Encoder 9. We are going with composite input to DV on the ADVC. Every time I change any parameters within WME9, the mode on the ADVC automatically switches from Analog --> DV to DV --> Analog, which then requires pressing the mode button in order to go back to Analog --> DV. I have looked at the settings and don't see any way to prevent this from happening. Since we do a lot of work using remote desktop, this is a major problem. There appears to be no way to change the ADVC mode from within WME or Windows. We are not using 9 pin control.
Any suggestions?
Thanks,
Cleiber
Any suggestions?
Thanks,
Cleiber
