Hi all. Brandon, I'm loving the 300 since you told me to change that dipswitch setting for sync. No more drop outs.
Now, I have yet another neophyte issue.
I am converting some old VHS videos that have an audio hum after capture and edit / playback through Adobe PE or PPro.
If I play the VHS directly into my TV, the volume is very low and when I turn the TV volume up I get a hum there too.
The only way I know of to normalize the sound and remove most of the hum is digitally through the equalizer effect in Adobe PP2.
Early on I learned that the picture controller software (much to my chagrin) is not designed to be open and running for real time tweaks while my VHS is playing. (or is that capturing?)
At any rate, I don't understand the audio settings very well even after looking at the manual. Is there something that will help with this issue in the setting of my capture?
thanks all!
thanks all!
