[ADVC-110] How to capture in 16:9 ?
  • [ADVC-110] How to capture in 16:9 ?
    Hello, I'm using the ADVC110 which is truly awesome. Great video quality !
    But the problem is that when I use Premiere, I can only get a 4:3 capture file ([email protected]) from a PAL source :( Is there some kind of dipswitch to enable to get a 16:9 output ?
    The workaround I have found is to capture to 720x576 (4:3) in AdobePremiere, then stretch the video to a 16:9 resolution, but the problem is that stretching a video makes it even worse. The best would be to be able to capture directly to a 16:9 ratio. What can I do ?
    Thanks in advance ;)
    You need to tell Premiere that the captured clip should be handled as 16:9.
    As for output, 16:9 DV is anamorphic like widescreen DVDs, so it's up to your display device to stretch the image to 16:9 aspect.
      OH MAN YOU ARE RIGHT !!!!! Thanks a lot ! It's been a month I've been using Adobe Premiere but I never noticed that I could chose Widescreen or Standard in the project menu. I was always chosing Standard as a habit.
      Thanks a lot and sorry for the "stupid question". Now I can safely say that the ADVC110 rocks :))))
        Have fun with it!
