Hi to all,
I used since more than two years the ADVC300 with Premiere Pro V1.5, without any problem.
I recently updated PP 1.5 to PP CS3, and can't no more initiate any capture in CS3. ADVC300 is always recognised in Windows XP Pro (can see incoming analog video in Windows desktop), and I think there is no problem with cables (in doubt, I changed it but same results).
In PP CS3, ADVC is seen connected, "Online" status when ADVC turned on, and "Offline" status when ADVC turned off. So, seems OK for physical connection. But Premiere says that device can't be driven and that I have to reconfigure it. Of course, tried some device profils as "Generic", "Canopus" and "Sony Standard", but no positive result.
For information, I use two external FireWire devices : Canopus ADVC300 and RME Fireface800, but each have a different IEEE1394 controller (on-board bus used with Fireface800 and added card - TI chipset - is used for the Canopus device). Never had problem with this configuration, when using in PP V1.5.
Any idea where to search ?
(search similar problems in this forum, but didn't found as mine)
(ADVC300 has already been flashed in the past, for PP 1.5 compatibility)
(tried to turn off Fireface800 - not work better)
(Computer is a WS only used for music composition - Cubase 4 - and video editing, no internet connection, WinXP Pro SP2 without any update)
In advance, all my thanks for any help.
Remy
Remy
