I am capturing old VHS and VHS-C tapes in order to convert them to DVD. I am in the US and am using all NTSC hardware. I am using the following equipment:
JVC SR-MV45 Professional line S-VHS/DVD combo VCR
Canopus ADVC-110
PC
I am also using an old school Sharp VC-A542 VCR for testing.
Here is my problem... I went through the hassle of capturing about 70 hours of old movies to my computer with the JVC and Canopus units. I set the Canopus unit to 7.5 IRE and captured away. The problem is that after burning my first movie I noticed the video was very dark. A digital waveform monitor in my NLE confirmed my suspicions. The captured video was about 16 digital units darker than the source.
After exhaustive testing I have determined that the drop in luma is caused by the Canopus ADVC110 unit especially when I enable the JVC's TBC feature. If I attach the JVC directly to my TV the luma values are fine, however if I place the ADVC unit between the VCR and TV the luma values drop.
I have made absolutely sure my IRE switch is set to 7.5IRE.
I also noticed there is significant distortion (jittery, wavy output) when the Canopus is in the chain.
I have attached a link to captured video clips at the bottom of this post along with a description of what the clips contain.
Here are my questions...
1. Is the drop in luma values normal for this Canopus unit?
2. Should I expect to see conversion artifacts (jittery, wavy) when playing video through the Canopus unit?
3. Why would the use of a TBC affect luma but only when the Canopus is involved?
Thanks in advance!
Clips
Color bars clip
Description: Color bars output in 7.5IRE mode by the Canopus ADVC110.
Recorded: Canopus ADVC110 in Color Bar mode -> JVC VCR via composite for recording.
Captured: Using the new JVC VCR via S-Video and my old Sharp VCR via composite to the Canopus unit.
TV clip
Description: A TV clip recorded off of broadcast cable around 2001.
Recorded: With a standard consumer VCR (I don't have it anymore).
Camcorder clip
Description: VHS camcorder footage from around 1987. Could be multigenerational.
Recorded: With an old Zenith camcorder that was purchased back in 1983.
Playback: On the new JVC VCR via S-Video and my old Sharp VCR via composite to the Canopus unit.
Canopus ADVC-110
PC
Thanks in advance!
Clips
Color bars clip
TV clip
Camcorder clip
