Hey everybody just wondering if anybody had an idea. I contacted customer support but the reply wasn't super helpful.
Question:
Hello. My lab has been using ADVC 55 (and 100) to capture video from NTSC cameras. In the past we used a direct show filter "Microsoft DV Camera and VCR" and were able to capture multiple video sources in a single program. recently we lost this capability and would like to know if this is still possible or if there is some sort of Windows SP2 firewire driver issue here. We find that when more than a single device ADVC device is plugged into a computer they no longer work properly. When the first device is connected the video can be previewed in an Explorer window. Once the second device is added, the new device is able to display a preview but the original device give the error:
Video Preview Failure
Creation of video preview failed.
Please check the device connection and make sure the device is not being used by another application or user.
Our basic question is how can we connect multiple ADVC devices and have them ready and available for capture. Any help is greatly appreciated.
Response:
The limitation on the ADVC's connected depends on the capture software that is used. Most capture software out there will become confused when multiple video sources are made available, so typically you will have to disconnect all but one. If the capture software is written to properly use multiple video sources however we have not seen any issue with using multiple ADVC's. Drivers are provided by the native operating system. We do not provide drivers.
Any help is greatly appreciated. Thanks.
Brendan
Question:
Response:
Brendan
