Hi all. I have the ADVC300 and for the most part enjoy using it. I am having an intermittent problem however that I'm not sure the cause of.
When I capture VHS to my HD, occasionally, without seemingly any reason, the capture simply stops. The VHS is a very clear taping with no visible static or interference.
When this happens the capture program freezes and in order to complete the save on the avi I have to power off the 300.
This happens with WinDV, with Adobe Premiere Elements, with CaptureFlux.
It can happen at 5 minutes or 55 minutes or anytime in between or after. No repeatable circumstances. Or, many times, it may not happen at all.
I'm capturing to an external PATA drive in a USB2 enclosure. It is maintained, defragged, and has plenty of free space.
I chose this method to allow full bandwidth on my firewire port for the ADVC300, and to keep the captures off my internal Operating System drive.
This is a dedicated computer for video. Never been connected to the internet, no virus apps running. In fact, nothing running in the background.
Its an annoying happening that has me wondering. I can go multiple VHS tapes before it happens and then when it decides to, it just stops and locks up the software.
Windows is not locked and I can close the programs properly, with saving all captures if I power off the converter.
After I restart the ADVC300 and re-open the capture program, usually I can complete the VHS without further incident. I don't get it.
Any ideas? or similar occurrences?
thank you,
joe
thank you,
joe
