Distinctions ACEDVio and ADVC 110?
  • Distinctions ACEDVio and ADVC 110?
    ADVC 110 gives digital output only with a compression (format VD).
    Can ACEDVio gives digital output without a compression? What here variants?
    Whether it is possible to adjust at ADVC 110 brightness/.../... on a source of a signal, how ACEDVio?
    What device is better on a sound?
    What device more universal at a possible choice software for the further processing?
    You can think of the ACEDVio as an OHCI-compliant Firewire board with an ADVC110 permanently attached (though it does auto-disconnect the converter when you plug a 4-pin FireWire device into the card).
    They both convert to/from DV or DVCAM format.
    You can adjust the input image brightness on the ACEDVio.
    If you plan to do image processing after capture, you should get a board that can capture to an uncompressed or lossless compressed file, like the EDIUS NX.
