When using Edius I can’t get the ADVC110 to output to my tv when playing back clips or scrubbing the timeline. I can capture ok. I can view from the timeline using Avid Xpress so it must be working ok. Can anyone help me? Maybe it’s my project settings; to be honest I am not that sure what they should be. I want to use the canopus to capture VHS video footage (pal) to the timeline, edit it and then out put to a dvd recorder through the canopus.
Thanks in advance
Pianoman
Thanks in advance
Pianoman
