I just bought a ADVC55 and so far everything seems to be working well, but there is minor annoyance/oddity. I'm using Sony Vegas 8 (Sony Video Capture 6.0) as the capture program, and when I plug the ADVC55 into the pc's IEEE port the capture application starts running the timeline immediately, even if there is no video input from the VCR yet. It's like it senses a DV signal from the ADVC unit and assumes there's something to capture. This doesn't happen when I plug my DV camcorder in to the IEEE port.
When I actually start the VCR the video is captured, but there is a short "blank" section at the beginning of the .avi file corresponding to the time it takes me to push the play button on the VCR and begin streaming the video signal to the ADVC55.
Like I said at the beginning, this is only a minor annoyance/oddity, but I'd like to eliminate it if possible.
PC specs: Dell E520, 2.4GHz Core2Quad cpu, Vista Ultimate 32bit, 4Gig ram with a PCI bus TI OHCI Compliant IEEE 1394 card.
Thanks in advance!
Ed
Thanks in advance!
Ed
