Replacement Converter Cable for ADVC1394
  • Replacement Converter Cable for ADVC1394
    My converter cable had a bent pin and I tried to straighten it but unfortunately I broke the pin. Is there anywhere I can buy a replacement cable? I figured that since the 1394 was older Canopus would not have a cable available.
    Thanks,
    Tyler
    If you're talking about the Composite adapter "pigtail" cable (that plugs into the 7-pin MiniDIN), don't shoot yourself down before you take off. Give support a call - a number of our products use that cable so we should have them.
      Thanks for the direction. I started searching again and low and behold I found a site that sells the adapters for dirt cheap! Its actually an ATI cable but it is identical to the one that came with the 1394. The website is http://www.directron.com/svideoadapter.html. I hope this helps others that are in my situation.
      Thanks again,
      Tyler
        Are you sure it's the same pinout?? I guess you're going to find out soon enough, as you seem to be opposed to contacting tech support...
        Let us know if it works.
