ADVC100 & 10.4 Compatability?
  • ADVC100 & 10.4 Compatability?
    Hello out there!
    I am successfully able to use my ADVC100 with Final Cut Pro (Ver. 3) using system 10.3, however recently, I jumped up to 10.4 on my laptop and unfortunately, the unit is no longer recognized.
    What can be done to get FCP 3 going in OSX 10.4? I do not use Imovie at this time.
    Any help helps helpfully,
    Thanks!
    I'd post this question on the Apple Final Cut Pro forums. You'll probably get a quick, concise answer from the Apple pros.
      Did you try the Apple forums? Any luck?
