After 6 or so years of use, the 4-pin DV port on the front right of my ADVC 100 has become worn, probably from frequent plugging and unplugging. On close inspection I see that the plastic insulation around the pins in the port has deteriorated. The end result is that the 4-pin input plug is not accepted, and I'm unable to use the unit.
I called Canopus support and was told that, aside from paying $240. for a new unit, I could try removing and resoldering a new 4-pin port on the card inside the unit. I had a look, but don't trust my skills for such a detailed job. The Canopus engineer also suggested getting a 4-pin FireWire PCI card to install in my G4 PowerMac, and then reversing the cable so that I would maintain the 4-to 6 pin connection, and connecting to the 6-pin port on the back of the converter.
I called OWC to see if they had something like that, and the sales agent said they didn't, and why didn't I just connect a 6-pin from the FireWire port on the G4 to the 6-pin port on the ADVC? Canopus didn't recommend that because they say the extra 2 pins carry power, and could affect the DC powered ADVC unit.
Any suggestions? Help is very much appreciated.
Thanks,
Keith
Thanks,
Keith
