Hi guys, can anyone advise me where the error is? Did I get Canopus ADVC 100 on eBay and when capturing the image has disturbing color stripes in video capture? Thank you
ADVC100 - Disruptive colored stripes
Originally posted by Lukas321 View PostHi guys, can anyone advise me where the error is? Did I get Canopus ADVC 100 on eBay and when capturing the image has disturbing color stripes in video capture? Thank you
With analog video this is common when capacitors are drying out or going off value (a common occurrence in many camcorders).
Are your settings correct for the ADVC-100? I don't have a manual available to look them up.
Do you see irregularities at similar positions when viewing the video from the same source and cables directly on a tv? They don't have to appear exactly like those thin sharp lines since it is analog, but could just look likr noisy like irregularities. The conversion to digital by the ADVC could be causing them to become those sharp lines, but this may not be a fault of the ADVC-100.
Does a different source (different VCR, Camera, etc.) cause the same issue? A clean signal from a newer source would be good to test, as the newer it is, the less likely it is to have capacitor issues.
Do you see the same issue with different cables? (swap both analog and firewire cables. You could also try the other firewire port on the ADVC-100)
Does your computer show anything like that on a direct firewire capture from a camera? Is the firewire port on your computer one that you know is working good?
Have you tried a different capture software?
If verifying settings, changing cables, sources and software still result in the same issue, then it is likely that you have a bad ADVC-100, since everything else will have been changed. (basic troubleshooting steps)Last edited by BernH; 02-22-2020, 03:09 PM.Edius WG 9.54.6706, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
