It has been a year since I worked with the ADVC300 and I do not remember
how to avoid losing capture between long scene changes on SVHS and HI8 source tape.
The kind of scene change when the tape may have been out of camcorder and put back in to record again and there is a section of tape that has no signal.
Or a scene change when camcorder was probably tunred of and back on again.
When that occurs (I think)the advc300 thinks the capture process has stoped, switces to digital input and stops capturing.
It is difficult to sit through 2 hrs of capture and monitor this,but the biggest problem is that this makes it inpossible to capture the entire tape in one file.
I prefer to capture entire tape in one avi file to edit later.
I know it has worked before as I just experimented with the same tape and recaptured it to compare with capture file from same tape a year ago.
I am losing capture at differnent points on tape each time I recapture.
And I am using same computer, with Video Studio 10 which is same program I always use.
And I capture in DV1 format which is said to be lossless since there is no compression.
Any ideals would be appreciated.
Thank you
jwalk2c
Thank you
jwalk2c
