ADVC3000 Question
  • ADVC3000 Question
    Is the SD-SDI output and/or the Composite Video output of the ADVC-3000 genlocked to the reference input? Are there genlock controls to adjust NTSC timing?
    Thanks,
    John
    I confess that I'm not the biggest expert on ADVC3000's sync capabilities, save to say that it is its own BlackBurst sync generator.
    Here's the manual, if that helps..
      Thank you, Kenneally.
      It appears that there is a single timing value for either the SDI or NTSC Composite output, but the outputs are definately genlocked to the reference input.
      John
