ADVC 110 Driver - USB and Firewire
  • ADVC 110 Driver - USB and Firewire
    We have an ADVC 110. Our computer doesn't have a firewire card, so we're using a simple usb to firewire adapter.
    The problem is with the driver and how it is installing. I get a message that the device is "Unknown" and I can't find a download for a manual install of the driver.
    Any suggestions?
    What OS are you using?
    I believe it uses the native IEEE1394 driers, not a special ADVC driver.
    If the ADVC is registered you can find the manual on the GV web site.
      can you add a $40 firewire card to your PC? or do you have no spare slots?
      make sure firewire card has Texas Instruments or VIA chip
      firewire cards with LSI chip crash EDIUS
        We're using Windows 7 on that computer. Do you know if there is a way to force install the firewire (IEE1394) driver on a computer for use with the adapter?
          Unfortunately we don't have any extra slots on that PC. We use it for video editing and we already have adapters/graphics cards in each of the slots.
          Does anyone have a link to an active usb to firewire adapter that might work better than the pass through we currently use?
          Also, do you have a link to the manual you mentioned?
            In general, with Win7 you should use the "legacy" IEEE 1394 driver, not the one Win7 installs as a default.
            You may be able to go through Windows Device Manager to install the correct driver.
            However, I don't know whether or not it will work through an USB-to-firewire adapter, or though a USB hub, especially if anything else is using the hub.
            What adapter are you using?
            What PC are you using?
              Canopus-110 Driver
              HI I am looking for the Canopus-110 device driver, can anyone help me as to where I can download it from?
                I have a 110. It did not have nor require a specific driver. It uses the generic firewire driver in windows and should show up as an AVC device if I recall correctly (mine is currently on loan to a friend so I can't confirm exactly what it is called.
                You may need to force it to use the legacy firewire driver in windows though, particularly if you are using Win10.
                Edius WG 9.54.6706, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
                  Legacy driver may be needed for Win 7 and Win 8 as well. For 8 and 10 it has to be d/l from a MS web site. It was shipped, but generally not activated, with Win 7.
