I just purchased the ADVC110. When I turn it on, not connected to PC, it comes up normally, with either digital or analog light on, and status light off. When I plug it into my PC with digital capture software running, it switches to all three lights on steady. Then it gets hung there and the only way to change it is to power off/on. I haven't been able to capture anything as yet - due to this issue.
capture software tried: Adobe premier pro, Windows media encoder, Studio 8, and several others.
It is possible the camcorder output it caputz. Would that cause this kind of behavior?
I'll try capturing from my TIVO next, but wanted to see if this was normal. The documentation for this hardware is, well, less than optimal.
