I'm trying to import S-Video 16:9 output from a PVR into iMovie / MacPro but I can only get a 4:3 image in both iMovie (the project is set to 16:9) and in Picture Controller preview. I've checked the dip switches on the ADVC300 and they're set as:- switch 4 - on, switch 5 - on. Am I missing something?
ADVC300 Aspect Ratio
The DIP switch settings you mentioned only affect what gets displayed on a monitor attached to the ADVC300. They have no effect on capturing.
Since an analog signal fed into the ADVC300 looks identical whether it is 4:3 or 16:9, the ADVC300 simply sets the flag in the captured DV stream to indicate that it is 4:3 (perhaps showing it's age!). You must then tell your editing application to override this setting and that it is really meant to be 16:9. Not sure if or how you can do this in iMovie (I'm nowhere near a Mac at the moment) but video editing applications that I have used on Windows allow me to override the aspect ratio property of source DV streams.
Ken.
