I have just acquired an ADVC-300 at great expense and use it with a new model Macbook Pro. As the software doesn't run in my Mac I have to make any adjustments on the box itself without being able to preview the results in real time like it seemed possible with the software. I have a headache trying to figure out how to make the adjustments despite having a copy of the instruction manual. The colours bleed and are not accurate with the original and of course the images are not clear so can anyone recommend what they consider to be the best settings to sharpen, reduce noise, correct colours and colour spill or bleed or whatever you call it when the colour smudges out from objects in the video. I believe it has a line based TBC but would you recommend using a full frame TBC as well? I'm sure this has all been covered in other postings it's just that I can find them.
I would really appreciate any education you could give me.
