ADVC 700 with Matrox RTX100
  • ADVC 700 with Matrox RTX100
    I use Matrox with Premiere Pro2
    For an high quality I buy ADVC700 for digitize video analog (YUV) Beta SP via Matrox
    But the result is not good .Is it a problem between codec Matrox and codec Canopus
    The ADVC700 should appear as a standard DV device - you should not need to transcode to a different codec. The captured file should be the same as capturing from a DV camera or deck.
