I just purchased this (will arrive next week) and hope to use it with my Mac/FCP to display rendered video from FCP onto my Color TV.
Some questions:
1. To "get" the video out to the 110, I assume I use Print to Video from within FCP.
2. Will the quality seen on the TV from the 110 be : Equal to, Lessor or Better than what will be seen when I burn the footage to DVD and play that via a DVD player (SD, not HD)?
Meaning, once I render in FCP I have to export and then the footage is encoded by DVD Studio Pro. How will the image compare to what the 110 displays? Or, should I export as DV ( I believe DSP encodes to DV) and play that back via quicktime? Or FCP itself? If I play back via quicktime, will the video come out via the 110 box to the TV?
3. What connection: composite or S-video will give the closest look to what the DVD will look like?
These are crucial issues as these DVDs are for clients.
thanks!
Some questions:
thanks!
